Photonics
Photonics
How to access variables in varfdtd from the script.
    • Vahram Voskerchyan
      How can I edit the varFDTD test potins x and y and also slab mode position x0 and y0 from the script. I have tried to set the test points like a column vector but didn't work.
    • Amrita Pati
      Hi Vahram,
      You can use the following code to edit the slab mode postions:
      setnamed("varFDTD","x0",0.0e-6);
      setnamed("varFDTD","y0",0.0e-6);
      You can save the test points in a 4X2 matrix (4 test points' x and y co-ordinates) and then use this with the setnamed command as shown below:
      V = [1e-6,1e-6;
      1e-6,-1e-6;
      -1e-6,-1e-6;
      -1e-6,1e-6];
      setnamed("varFDTD","test points",V);
      Please let me know if you have any further questions.
      Amrita
  • The topic ‘How to access variables in varfdtd from the script.’ is closed to new replies.
