May 19, 2023 at 7:53 am
John Miller
SubscriberHello together,
I’m working on an FDM AM simulation and got some troubles with the postprocessing.
The simulation with ekill and alive is working just fine. I’m trying to plot the thermal flux at the contact surface and the thermal contact conductance via APDL snippet:
! Commands inserted into this file will be executed immediately after the ANSYS /POST1 command.
! Active UNIT system in Workbench when this object was created: Metric (m, kg, N, s, V, A)
! NOTE: Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
! See Solving Units in the help system for more information.
step_nr=ARG1 ! here ARG1 = 1 the first load step
set,step_nr
*stat
esel,s,type,,mycid !
! set colors for white background
/RGB, INDEX,100,100,100, 0
/RGB, INDEX,80,80,80, 13
/RGB, INDEX,60,60,60, 14
/RGB, INDEX,0,0,0, 0
/show,png
/view,1,1,1,1
ples,cont,flux ! plot heat flux through contact elements
etable,tcc_i,nmisc,94
plet,tcc_i,1
allsel
! plot 1 = thermal flux at the contact surface
! plot 2 = applied thermal contact conductanceThe problem is that the deactivated elements are covering the print bed contact with the extruded material. In the picture, you can see the print bed (big cuboid) and the extruded material (small cuboid). Is there a way to fade out the extruded part to reveal the contact area?
With best regards
John M.
May 22, 2023 at 12:27 pm
Chandra Sekaran
Ansys EmployeeMay be use /trlcy,cm,name,0.7 to get the elements you do not care about to show with translucency? You can also unselect the elements.
May 25, 2023 at 10:16 am
John Miller
SubscriberHello Chandra,
thank you for your helpfull answer.
When I apply the changes the plot isn’t still what I indended.
Here is my applied script:
/graphics,power
/post1
step_nr=5
set,step_nr
*stat
/show,png
/trlcy,cm,0,bed
/trlcy,cm,0,bed2
/trlcy,cm,1,path
esel,s,ename,173
/trlcy,elem,0
esel,all
/view,all,1,1,1
/angle,1,0,ZM,0
/angle,2,0,ZM,0
/eshape,1ples,cont,flux ! plot heat flux through contact elements
plet,tcc_i,1
allsel
! plot 2 = applied thermal contact conductanceThe plots are looking this way:
The solve out file shows this:
***** ANSYS RESULTS INTERPRETATION (POST1) *****
*** NOTE *** CP = 413.531 TIME= 13:48:38
Reading results into the database (SET command) will update the current
displacement and force boundary conditions in the database with the
values from the results file for that load set. Note that any
subsequent solutions will use these values unless action is taken to
either SAVE the current values or not overwrite them (/EXIT,NOSAVE).PARAMETER ARG1 = 5.000000000
Use PowerGraphics for solid and shell elements
Facet level set to 1 for maximum speed
Use /EFACET,2 for curved boundaries.
You have already entered the general postprocessor (POST1).PARAMETER STEP_NR = 5.000000000
USE LOAD STEP 5 SUBSTEP LAST FOR LOAD CASE 0SET COMMAND GOT LOAD STEP= 5 SUBSTEP= 1 CUMULATIVE ITERATION= 5
TIME/FREQUENCY= 0.25000
TITLE= RADuCONV--Thermisch-transient (A5)ABBREVIATION STATUS-
ABBREV STRING
SAVE_DB SAVE
RESUM_DB RESUME
QUIT Fnc_/EXIT
POWRGRPH Fnc_/GRAPHICSPARAMETER STATUS- ( 84 PARAMETERS DEFINED)
(INCLUDING 24 INTERNAL PARAMETERS)NAME VALUE TYPE DIMENSIONS
ABC -1.00000000 SCALAR
AX 5.000000000E-004 SCALAR
BX 0.00000000 SCALAR
CID 7.00000000 SCALAR
DT 5.000000000E-002 SCALAR
DTCOOL 0.100000000 SCALAR
DY 5.000000000E-004 SCALAR
DZ 5.000000000E-004 SCALAR
HC_A 100.000000 SCALAR
HC_B 80.0000000 SCALAR
HC_C 60.0000000 SCALAR
HC_EX_COOL 30.0000000 SCALAR
HC_OUT 30.0000000 SCALAR
I 20.0000000 SCALAR
ICOOL 1.00000000 SCALAR
II 1.00000000 SCALAR
IIJJ 2.00000000 SCALAR
IJK 2.00000000 SCALAR
J 1.00000000 SCALAR
JJJ 1.00000000 SCALAR
KK 20.0000000 SCALAR
LC 1.00000000 SCALAR
PC 1.00000000 SCALAR
PDY 1.000000000E-003 SCALAR
SC 1.00000000 SCALAR
STEP_NR 5.00000000 SCALAR
T 1.00000000 SCALAR
TA 80.0000000 SCALAR
TB 60.0000000 SCALAR
TBED 40.0000000 SCALAR
TBULK 25.0000000 SCALAR
TC 50.0000000 SCALAR
TCC2 TABLE 2 1 1
TEMPERATURE TEMP CHARACTER
TEX_COOL 40.0000000 SCALAR
THXY1 0.00000000 SCALAR
THXY2 0.00000000 SCALAR
THYZ1 0.00000000 SCALAR
THYZ2 0.00000000 SCALAR
THZX1 0.00000000 SCALAR
THZX2 0.00000000 SCALAR
TID 8.00000000 SCALAR
TL 70.0000000 SCALAR
TOL 1.000000000E-006 SCALAR
TOUT 10.0000000 SCALAR
TR 0.100000000 SCALAR
VX 1.000000000E-002 SCALAR
XLOAD 5.000000000E-004 SCALAR
XR1 1.000000000E-002 SCALAR
XR2 8.000000000E-003 SCALAR
X_BOX_B 5.000000000E-004 SCALAR
X_BOX_C 5.000000000E-004 SCALAR
YCORR 1.000000000E-003 SCALAR
YLOAD 5.000000000E-004 SCALAR
YR1 1.500000000E-003 SCALAR
YR2 1.500000000E-003 SCALAR
Y_BOX_B 5.000000000E-004 SCALAR
Y_BOX_C 5.000000000E-004 SCALAR
ZR1 5.000000000E-004 SCALAR
ZR2 5.000000000E-004 SCALARPARAMETER PRIMARY VARIABLE LISTING-
NAME VARIABLE(S)
TCC2 1=TEMP 2= 3=*** WARNING *** CP = 413.969 TIME= 13:48:39
Specified range of 0 to 0 is not permitted. The ESEL command is
ignored.RED=100% GREEN=100% BLUE=100%
for color index 0.RED=80% GREEN=80% BLUE=80%
for color index 13.RED=60% GREEN=60% BLUE=60%
for color index 14.RED=0% GREEN=0% BLUE=0%
for color index 0./SHOW SWITCH PLOTS TO PNG - RASTER MODE.
COMPONENT BED TRANSLUCENCY SET TO 0.0000
COMPONENT BED2 TRANSLUCENCY SET TO 0.0000
COMPONENT PATH TRANSLUCENCY SET TO 1.0000*** WARNING *** CP = 414.016 TIME= 13:48:39
For item = ENAME, component = 173 is invalid. The ESEL command is
ignored.
ALL ELEM TRANSLUCENCY SET TO 0.0000ALL SELECT FOR ITEM=ELEM COMPONENT=
IN RANGE 1 TO 99718 STEP 184182 ELEMENTS (OF 84182 DEFINED) SELECTED BY ESEL COMMAND.
view point for window 1 1.0000 1.0000 1.0000
ROTATION ANGLE FOR WINDOW 1 IS 0.00 ABOUT AXIS ZM
ROTATION ANGLE FOR WINDOW 2 IS 0.00 ABOUT AXIS ZM
ELEMENT DISPLAYS USING REAL CONSTANT OR SECTION DATA WITH FACTOR 1.00
DISPLAY ELEMENT SOLUTION, ITEM=CONT COMP=FLUX
CUMULATIVE DISPLAY NUMBER 1 WRITTEN TO FILE file000.png - RASTER MODE.
DISPLAY TITLE=
RADuCONV--Thermisch-transient (A5)STORE TCC_I FROM ITEM=NMIS COMP= 94 FOR ALL SELECTED ELEMENTS
*** WARNING *** CP = 415.156 TIME= 13:48:39
The ETABLE command has requested item = NMISC, comp = 94 of element 1
(element type SOLID279). 0.0 is output, as this item does not exist.
Checking for this discontinues.DISPLAY ELEMENT TABLE, ITEM=TCC_I OPER=1
*** NOTE ***
libpng version 1.0.8 - July 24, 2000
Copyright (c) 1998-2000 Glenn Randers-Pehrson
Copyright (c) 1996, 1997 Andreas Dilger
Copyright (c) 1995, 1996 Guy Eric Schalnat, Group 42, Inc.ZLIB Version 1.2.11 Copyright (C) 1995-1998 Jean-loup Gailly and Mark Adler
CUMULATIVE DISPLAY NUMBER 2 WRITTEN TO FILE file001.png - RASTER MODE.
DISPLAY TITLE=
RADuCONV--Thermisch-transient (A5)SELECT ALL ENTITIES OF TYPE= ALL AND BELOW
PARAMETER LOADSTEP = 1.000000000
USE LOAD STEP 1 SUBSTEP LAST FOR LOAD CASE 0SET COMMAND GOT LOAD STEP= 1 SUBSTEP= 1 CUMULATIVE ITERATION= 1
TIME/FREQUENCY= 0.50000E-01
TITLE= RADuCONV--Thermisch-transient (A5)*GET NUMNODE FROM NODE ITEM=COUN VALUE= 283054.000
SET PARAMETER DIMENSIONS ON NODETEMP
TYPE=ARRA DIMENSIONS= 283054 4 1VECTOR GET OPERATION nodetemp(1,1) VECTOR LENGTH= 283054
NAME= NODE 1 LOC XVECTOR GET OPERATION nodetemp(1,2) VECTOR LENGTH= 283054
NAME= NODE 1 LOC YVECTOR GET OPERATION nodetemp(1,3) VECTOR LENGTH= 283054
NAME= NODE 1 LOC ZVECTOR GET OPERATION NodeTemp(1,4) VECTOR LENGTH= 283054
NAME= NODE 1 TEMPOPENED FILE= myTempfileWF.txt FOR COMMAND FILE DATA
MAXIMUM TERM IN RESULT VECTOR= 1STRIDE IN VECTOR OPERATION= 1
COMMAND FILE CLOSED
PARAMETER NODEID = 27844.00000EXIT THE ANSYS POST1 DATABASE PROCESSOR
I’m only interested in the display of the contact 173 elements and the heat flux through these elements. But I can’t plot it this way. The grey part named “path” should be transparent but it’s not. The underlying “bed” and “bed2″ should be not transparent, this is right in the second plot.
With best regards
John M.
May 26, 2023 at 3:23 pm
John Miller
issue is solved.
Everthing is working just fine.
With best regards
John M.
- The topic ‘/post1 trouble wtith Ansys Workbench thermal transient’ is closed to new replies.
4863
1587
1386
1242
