December 6, 2017 at 11:24 pm
oyallou
SubscriberI am trying to run a 3-D flow simulation over a wing. A couple days back, I ran the simulation with no problems. I have refined my mesh a bit and reduced the computational domain just to check grid independence of the results but no FLUENT kicks out every time I try to run my calculations. I have included a screen shot of the message I get. Any help would be greatly appreciated. Thank you
December 6, 2017 at 11:56 pm
raul.raghav
SubscriberSince you mention that your simulation ran earlier with no issues, and now after refining the mesh it shows up this error, I think it would be because of the number of nodes in your mesh. Can you provide some numbers? No. of nodes (before refining and after refining), RAM specs?
December 7, 2017 at 12:03 am
oyallou
SubscriberThat would make sense. I believe before refining the mesh, the number of nodes were under 500k. Now, the number of nodes reaches nearly 2 million.
The RAM on the computer is 3.49 GB available.
December 7, 2017 at 12:06 am
raul.raghav
SubscriberQuick question: How much is the total RAM in the computer?
December 7, 2017 at 12:07 am
oyallou
SubscriberThere is 4 GB of RAM installed.
December 7, 2017 at 12:09 am
raul.raghav
Subscriber -
December 15, 2021 at 1:11 am
aoduabiodun
Subscriber.I am running simulation based on electro-thermo-convection in a square cavity. The simulation give no error for low Rayleigh number (10000) and Electric Rayleigh Number (200). However, for a high Rayleigh number (50000) and at a constant Electric Rayleigh Number (200) an error occurred after series of simulation. Could anyone kindly provide any possible solution to this issue. The below is the screenshot of the problem am encountering. Thanks in anticipation.
November 22, 2022 at 3:12 pm
Imam Tantowi
SubscriberHello Oyallou, I have the same problem. Have you find the solution to this problem?
Thank You!
Imam
- The topic ‘“The fl process could not be started”’ is closed to new replies.
4838
1587
1386
1242
