April 14, 2023 at 5:29 pm
Élio Pereira
SubscriberI am using Ansys FLuent Solution 2021 R2 and I cannot find a TUI command for checking "Prevent Reverse Flow" when defining a pressure outlet boundary condition. I tried searching on the respective TUI manual, and there is no reference to it. So, is there no way to check such option through TUI?
April 17, 2023 at 12:42 pm
Nikhil N
SubscriberHello,
Try this out: 'define/boundary-conditions/set/pressure-outlet/'
Once you select zone(s), you will find this: 'prevent-reverse-flow?'
April 18, 2023 at 1:05 pm
Élio Pereira
SubscriberThanks Nikhil.
I can indeed confirm that such command works.
The trick is to use that “set” before “/pressure-outlet”, that is,
/define/boundary-conditions/set/pressure-outletinstead of
/define/boundary-conditions/pressure-outlet.
- The topic ‘Fluent Solution TUI – command for checking “Prevent Reverse Flow”’ is closed to new replies.
1565
1386
1242
