April 12, 2023 at 3:28 pm
Amin Zarandi
SubscriberI am getting this error in HFSS and I need your help:
Parasolid Error: The transformation would result in body lying outside the size box.
April 14, 2023 at 6:47 am
Chinmay T
Forum ModeratorHello,
Did you create the model or import it into AEDT?
Please let us know what kind of simulation you are doing and share more details on your model with the screenshots.
Thank you,
Chinmay -
April 14, 2023 at 1:27 pm
Amin Zarandi
SubscriberHi,
I figured out the issue. I was changing my units to um and after creating a radiation region for 40 MHz analysis it was giving me that error which is related to the maximum size limitation of HFSS. After changing the units to mm the problem got solved
- The topic ‘HFSS Parasolid Error’ is closed to new replies.
1311
