Export Fluent Results with node ID
    • l.geronzi
      I am executing some simulations with a parametric mesh in Fluent (running in parallel).
      For every mesh, I would like to export the pressure at the wall or the wall shear stress for example.
      In the journal, I'm using /file/export ascii wss (2 3 4 5 6 7 8 9 10) yes wall-shear () no
      where from (2.... to 10) are the surfaces of the mesh. It works but nodes are always numbered from 1 to n and there is no nodal correspondence (probably due to the parallel partition?). It means that in row 1 sometimes I have node 2034, sometimes node 6885, sometimes node 99999 ecc.
      I need to create a list where on row x there are always results associated with the same node id even if its position has changed in space due to the modified parametric mesh.
      How can I do? Is it possible to export Node Id in Fluent?
      P.S. I know that CFD post is a solution but I need to do it directly in Fluent.
      Thank you.
      Fluent is an unstructured solver, and the node IDs aren't necessarily static definitions: it's why it's always a good idea to write case and data on finishing a run.
      What exactly are you trying to figure out?
    • l.geronzi
      Ok, it’s a pity. I need to create a ROM (without using the RBP extension).
      At this point, CFD post is the only possibility. I put here the solution I will use in CFD-Post if any user will be interested in future. I stored the solution for every parametric mesh in a new cas and dat file.
      I used a loop in CFD-Post where n is the number of simulations.
      COMMAND FILE:
      CFX Post Version = 23.1
      END
      DATA READER:
      Clear All Objects = false
      Append Results = true
      Edit Case Names = false
      Multi Configuration File Load Option = Last Case
      Open in New View = true
      Keep Camera Position = true
      Load Particle Tracks = true
      Construct Variables From Fourier Coefficients = true
      Open to Compare = false
      Files to Compare =
      END
      !$i = 1;
      !while ($i < n){
      !if($i<2){
      DATA READER:
      Run Selection = “Simulation/Run/cff-restart-dat”
      END
      >load filename=D:/Leonardo/ROM_DT/ROM_SSM_files/dp0/FLU-1/Fluent/SSM-$i.cas.h5, force_reload=true
      !else {
      DATA READER:
      Domains to Load=
      END
      > load filename=D:/Leonardo/ROM_DT/ROM_SSM_files/dp0/FLU-1/Fluent/SSM-$i.cas.h5, \
      case=Case SSM 1.cas, force_reload=true
      EXPORT:
      ANSYS Export Data = Element Heat Flux
      ANSYS File Format = ANSYS
      ANSYS Reference Temperature = 0.0 [K]
      ANSYS Specify Reference Temperature = Off
      ANSYS Supplemental HTC = 0.0 [W m^-2 K^-1]
      Additional Variable List =
      BC Profile Type = Inlet Velocity
      CSV Type = CSV
      Case Name = Case SSM 1.cas
      Export Connectivity = Off
      Export Coord Frame = Global
      Export File = D:/Leonardo/ROM_DT/ROM_SSM_files/user_files/wss-$i.csv
      Export Geometry = On
      Export Location Aliases =
      Export Node Numbers = On
      Export Null Data = On
      Export Type = Generic
      Export Units System = Current
      Export Variable Type = Current
      External Export Data = None
      Include File Information = Off
      Include Header = On
      Location = arch
      Location List = arch,ascending_aorta,bc,descending_aorta,end_ascending_aorta,\
      high_valsalva_sinuses,lcc,low_valsalva_sinuses,ls
      Null Token = null
      Overwrite = On
      Precision = 8
      Separator = “, “
      Spatial Variables = X,Y,Z
      Variable List = Wall Shear
      Vector Brackets = ()
      Vector Display = Scalar
      END
      >export
      !$i ++;
  • The topic ‘Export Fluent Results with node ID’ is closed to new replies.
