March 27, 2023 at 11:23 am
Alessandro Agostinelli
SubscriberHi,
I'm trying to find the compliance factors of a curved beam flexure. The geometry is a simple curved beam (R=30mm, angle=45°) with a rectangular shape section (w=6 mm,t=1.2mm), like that:
I fixed one end and applied the force vector components (one by one) at the other one; then, I measured the displacements/rotations at the free end and divide displacement by force (or rotation by moment) to obtain the compliance factors, but I dind't get the correct results.
The correct compliance factors are analitically calculated (m/N or rad/Nm) compared to coordinate system "g" fixed at free end (like in previous picture, where x_g is red and z_g is green):
How can I do to obtain the same results with a FEA?
April 8, 2023 at 3:29 pm
dlooman
Ansys EmployeeThe general procedure is correct. You mention coordinate systems. The Ansys input and results are probably in global cartesian unless you have transformed them. Are the analytical results perhaps in a cylindrical coordinate system? You didn't give the Ansys results. How "incorrect" were they?
April 8, 2023 at 3:54 pm
peteroznewman
SubscriberDave, this a a duplicate discussion. The first discussion has some replies.
- The topic ‘Compliant Mechanisms’ is closed to new replies.
6269
