triangular elements in meshing
    • feroz.mulani85
      I tried to remove triangular elements in meshing by following methods,
      automatic method -> quadrilateral dominant.
      But still some triangular elements are appearing in the domain as shown below
      Please suggest me how i can get rid off these triangular elements.
      thanks
      What did you set?
    • feroz.mulani85
      i set to quadrilaterals only.
    • NickFL
      For that rectangle you can use Face Meshing (formerly Mapped Face). If you just say Quad Dominate, I think it is using the old paver approach that will stick triangles in occasionally.
  • The topic ‘triangular elements in meshing’ is closed to new replies.
