3D Design
3D Design
CATIA V6 / 3dxml files opening in Discovery
    • tim.dukes
      Hi Support,
      A customer is trying to import a 3dxml file and this doesn't seem to work in any of the Discovery products.
      I have just downloaded one from Grabcad attached and get the same error. I have attached this.
      Is this due to the limitation in the thread below re. authoring?
      /forum/forums/topic/open-3dxml-file/
      Tim
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello Tim Dukes
      Yes, it's due to same reason that the file doesn't contain authoring data. If you expand the Status History located at the bottom of Discovery SpaceClaim, you will see this message. Refer below snapshot.
  • The topic ‘CATIA V6 / 3dxml files opening in Discovery’ is closed to new replies.
