3D Design
3D Design
Problem with error message
    • Yohann Biran
      A client of Discovery spaceclaim enterprise with 3 floating licenses from Spaceclaim. He doesn't have the facet module.
      When it starts Spaceclaim, it has the attached error message ?
      So the error message seems logical, on the other hand, the message is there each time Spaceclaim is opened. How to stop the message?
      Best regard
      Yohann
    • Brian Bueno
      NOVACAD
      Look in File > SpaceClaim Options > License and make sure the STL module is not selected.
    • Yohann Biran
      Hi Brian,
      The STL Module is not selected for the customer.
      Do you have an other idea ?
      Best regards
      Yohann
      • Brian Bueno
        NOVACAD
        Is the option for the Facets ribbon tab set to active in SpaceClaim Options > Customize > Ribbon Tabs?
        We're basically looking for any setting that would try to obtain the Facets tools license.
    • Yohann Biran
      As you can see in PJ, the customer does not have the facet module in the list, so this one is not checked!
      Do you have another idea?
      • Brian Bueno
        NOVACAD
        This is still quite mysterious.  Maybe something is left over from an old trial that did have the STL module?
        Have the user go to C:\Users\ < user name > \AppData\Local\SpaceClaim and delete all the folders there.
    • Yohann Biran
      Hi Brian,
      The client tried to delete the files in the directory mentioned above but the problem persists.
      The client also has SCDM licenses on the same license server. It seems to me that the facet module is automatically in the SCDM licenses ?
      Maybe there is a conflict between the two licenses?
      Yohann
    • Yohann Biran
      Hi Brian,
      Did you have an idea for the subject of this ticket ?
      Best regards
    • Yohann Biran
      Hi Brian,
      Can you give me feedback on the above subject?
      Best regards
    • Brian Bueno
      Matt Madore
      Floating license here is not picking up the STL Prep option.  Any ideas?
    • ANSYS_MMadore
      It seems the error is correct, they don't have the license, so they would see the error.  They can try unchecking the "STL Prep" box under "License" within the SpaceClaim Options?
    • Yohann Biran
      Hi Matt,
      We've already tried, but the box is already unchecked.
      Best regards
    • ANSYS_MMadore
      I see you adjusted "C:\Users\ < user name > \AppData\Local\SpaceClaim", did you also try deleting "C:Users\ < user name > \AppData\Roaming\SpaceClaim"?
      Thanks,
      Matt
    • Yohann Biran
      Yes the custumer also try this but it's not change the problem...
    • Ichiro
      How about this idea below?
      Delete  < string > AdditiveMfg < /string > in user.config
      user.config:
                  < setting name="AnsysLicenseInclusions" serializeAs="Xml" >
                      < value >
                           < ArrayOfString xmlns_xsd="http://www.w3.org/2001/XMLSchema" xmlns_xsi="http://www.w3.org/2001/XMLSchema-instance" >
                          < /ArrayOfString >
                      < /value >
                   < /setting >
      Thanks,
        Ichiro
Viewing 12 reply threads
  • The topic ‘Problem with error message’ is closed to new replies.
