3D Design
3D Design
AIM APDL Solve Error (input/output error & out-of-core)
    • marcellszeles
      I have a complex model in AIM looking to be solved, and I'm having issues with the out-of-core performance.
      Can you kindly let me know which command (and which part to enter it) is used to run the "Distributed Sparse Matrix Solver" in "in-core" mode?
      Errors:
      /COM,ANSYS RELEASE 2019 R2           BUILD 19.4      UP20190416       18:16:19
       *** WARNING ***                         CP =       0.422   TIME= 18:16:20
       BCSOPTIO is not a recognized BEGIN command, abbreviation, or macro.
       This command will be ignored.
       *** WARNING ***                         CP =      37.328   TIME= 18:16:34
       The program chosen initial timestep/load-factor is arbitrary.  It is
       necessary for the user to supply a suitable initial
       timestep/load-factor through the NSUB or DELTIM command for
       convergence and overall efficiency.
       *** WARNING ***                         CP =     154.500   TIME= 18:17:26
       Component C1 does not exist.  The OUTRES command is ignored.
      /COM,ANSYS RELEASE 2019 R2           BUILD 19.4      UP20190416       18:18:02
       *** WARNING ***                         CP =       0.406   TIME= 18:18:04
       *** WARNING ***                         CP =      36.375   TIME= 18:18:16
       Element shape checking is currently inactive.  Issue SHPP,ON or
       SHPP,WARN to reactivate, if desired.
       *** WARNING ***                         CP =     264.672   TIME= 18:22:07
       The Distributed Sparse Matrix Solver is currently running in the
       out-of-core memory mode.  This memory mode may provide significantly
       worse performance compared to the in-core memory mode, depending on
       the amount of available system memory and I/O speed.  Please monitor
       the solver performance to ensure that the large amount of I/O to the
       solver files does not create a bottleneck for performance.
       *** ERROR ***                           CP =     333.172   TIME= 18:23:17
       An input/output error has occurred while trying to open a file with
       length = 33 GB.  Error code = 112, which translates to: There is not
       enough space on the disk.
       The program is unable to open file file1.DSPtri.  If the suggestions in
       the associated error messages immediately preceding and/or following
       this error message do not help resolve the file issue, please send the
       data leading to this operation to your technical support provider,
       along with the I/O error code of -1 and the system error code of 0,
       for help in determining the possible reasons as to why this file could
       not be opened.
       An input/output error has occurred on the process with MPI Rank ID = 1.
        This error occurs when trying to open a file with length = 34 GB.
       Please check to make sure there is enough free disk space in the
       working directory (D:Ansys ProjectsG¸ttlerrun-2 -
       v1_filesdp0StudyAIMphysics2) on machine (MARCELL-HPZ4).
      Thanks in advance,
      Marcell
    • Brian Bueno
      marcellszeles
      I will ask our team of experts and let you know their recommendation.
  • The topic ‘AIM APDL Solve Error (input/output error & out-of-core)’ is closed to new replies.
