May 31, 2021 at 8:18 amRobertoSubscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
HelloÂ
Can I send you a file privately?
When I insert this file into the drawing, the file does not appear why? How do I fix the problem?Best Regards
May 31, 2021 at 10:02 amSubashni RavichandranForum Moderator
Hello Roberto
Thanks for sharing the files. I have removed them from the Forum.
I'll look into it and get back to you
June 1, 2021 at 7:35 amSubashni RavichandranForum Moderator
Hello Roberto
I checked the model shared and I observed that the Model works fine with Shaded and Wireframe geometry but does not show correctly in the drawing sheet when the geometry is set to Hidden lines and Hidden lines removed.
I have shared my screenshots with you over email.Â
I will check with my team here and investigate what could be the issue and file a bug as needed. -
July 1, 2021 at 7:22 amRobertoSubscriber
Hello Subashni
When you have news let me know
Best Regards
August 5, 2021 at 6:29 am
- The topic ‘Problem drawing’ is closed to new replies.
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
1316
591
569
525
366
