June 23, 2021 at 3:16 pm
June 24, 2021 at 4:16 amCharudatta BandgarForum Moderator
Hello Pablo
It could be due to the settings with the decimal separator set in the windows setting, which isn't recognizing, as a decimal point. Let me look into this. As a workaround for time being, please use . as a decimal separator and see if it helps.Â
Regards.
- The topic ‘SpaceClaim dimension bug’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
591
544
524
366
