November 11, 2021 at 8:42 am
smjang
SubscriberHello This time, while supporting a customer, a message similar to the attached image occurred, and we contacted you. First of all, it is a warning message, so I ignored it and checked the result. Is there any way to solve the problem shown in the attached image?? When I looked at the SpaceClaim function, I can't remember the available functions. I think it means that the part where the microha is floating is connected, but I ask if I can ignore it and proceed with the simulation. thank you.
November 11, 2021 at 8:54 am
Devendra Badgujar
Forum ModeratorHi smjang Please check the below link for the solution to the warning message you are receiving: Discovery Contacts Warning: "Some surfaces are too far apart to connect. Adjust the surfaces to be closer." - Knowledge Base - Ansys Discovery Forum Regards.
- The topic ‘Discovery Connect warning message’ is closed to new replies.
Ansys Innovation Space
1328
1163
1090
1014
