December 1, 2021 at 2:17 pmRobertoSubscriber
HelloÂ
Has the following Bug been fixed in the next version?
Regards
December 1, 2021 at 2:26 pmCharudatta BandgarForum Moderator
Let me check Roberto
Regards.
December 1, 2021 at 2:55 pmCharudatta BandgarForum Moderator
Hello Roberto
Yes the bug is fixed in 2022R1.
Regards.
December 1, 2021 at 4:28 pmRobertoSubscriber
Charudatta Bandgar HelloÂ
Thanks for giving me this good news , now I will wait for you to update me also regarding the size of the external files
- The topic ‘bug number 351019’ is closed to new replies.
Ansys Innovation Space
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
591
569
525
366
