March 21, 2022 at 8:35 am
Roberto
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
HelloÂ
1) When creating a BOM table it is not possible to delete a row is it a BUG?
It is a limitation because it is not possible to modify the table
2)Â When with the toolbox module I insert the washers in the bill all at once, the washers are added while if the washers do not add them all at once the washers do not add them and are seen as different components
Regards
March 21, 2022 at 8:36 am
Devendra Badgujar
Forum ModeratorHi Roberto
Let me check and get back to you.
March 21, 2022 at 9:21 am
Devendra Badgujar
'Delete row' allows you to delete only empty/manually added rows.
If you would like to remove any of the components from your BoM, you can hide the component in your structure tree and then, in the BoM properties, you can toggle 'Hidden Components' to 'Do not include'. (refer image).
This option will eliminate the components hidden in your Structure tree, from the BoM.
When with the toolbox module I insert the washers in the bill all at once, the washers are added while if the washers do not add them all at once the washers do not add them and are seen as different componentsPlease can you share a short video or image of this issue related to toolbox module to understand the problem better.Â
Regards.
March 21, 2022 at 9:50 am
Roberto
SubscriberHello  Devendra Badgujar
Thanks for giving me a solution, regarding the second problem now it no longer occurs.
As soon as it occurs again I will notify youÂ
regards
March 21, 2022 at 10:02 am
Devendra Badgujar
Forum ModeratorRobertoÂ
Thanks for the update.Â
- The topic ‘BOM table and toolbox’ is closed to new replies.
5799
1305
