March 5, 2023 at 4:24 am
chonkiat.lee
SubscriberHow to generate PSD force in Workbench? I only able to find acceleration, displacement, stress but no force...
Thank you! -
March 5, 2023 at 2:25 pm
peteroznewman
SubscriberWorkbench has implemented the most common forms of PSD input. Acceleration, Velocity and Displacement are common because vibration is usually measured using an accelerometer. How did you end up with a Force PSD?
To use a Force PSD in Workbench, you have to use a Command object.
Look up the command PSDUNIT.
Use Type = FORC
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/ans_cmd/Hlp_C_PSDUNIT.html
March 6, 2023 at 1:44 pm
chonkiat.lee
SubscriberThanks Peter. I might not be clear in my question. When we generate frequency response, we are able to have acceleration, displacement, etc but not force. Wonder if Workbench can generate it?
March 6, 2023 at 6:04 pm
peteroznewman
SubscriberAh, okay, I thought you were asking about Inputs, which I answered. You want to know about Response PSD output like the one for relative acceleration that I show below.
You want to know if you can plot a Response PSD for Force. I don't think so. Maybe someone else will comment.
I know you can obtain the 1 sigma value of the Reaction Force at the Fixed Support.
September 8, 2023 at 2:55 am
Noah Brown
SubscriberÂ
To generate PSD force in Workbench, you can follow these steps:
- Go to the Mechanical application in Workbench.
- Create a new Static Structural analysis system.
- Import your geometry and apply the necessary boundary conditions and loads.
- Go to the Solution tab and create a new Modal analysis system.
- Set up your modal analysis by specifying the desired modes and frequency range: immaculate grid
- Go to the Solution tab and create a new Random Vibration analysis system.
- Specify the PSD input in the Random Vibration analysis system by selecting the desired PSD function and inputting the necessary parameters.
- Run the simulation to generate the PSD force.
You’re welcome!
- The topic ‘Random Vibration PSD Force’ is closed to new replies.
6465
