Error: wta(1st) to symbol->string
    • k1465822
      Hello guys,
      I was able to apply periodic boundary condition and ran my single blade compressor simulation in Fluent 2021 R2 (abled to run simulation without a single error) and when i changed in to 2022 R1 version (University updated the version) , i am getting following error,
      Error; Object: #f
      Can someone help me one this (attached a picture of error as well)
    • SRP
      I recommend that you try to transfer the data using interpolation files.
      https://youtu.be/Wo59YAj-Ngk
      Hope this helps you to avoid error.
      Thank you
      Saurabh
      • k1465822
        Thank you very much for your reply.
        this error appears when setting up periodic boundary conditions for the simulation.
  • The topic ‘Error: wta(1st) to symbol->string’ is closed to new replies.
