Fluid-Structure Interaction for a moving body
    • Mahmoud Nassar
      I am trying to solve an oscillating airfoil using system coupling between Fluent and transient structure.
      I was able to successfully run the benchmark problems for FSI on its own. Further, I was able to solve an oscillating airfoil by imposing the motion to the airfoil as a rigid body using Define Cg motion and dynamic mesh.
      Now, my question is how I can impose the motion for the airfoil in fluent and also define the same airfoil as a system coupling ?!
      The airfoil is flexible and I have to use 2-way FSI
      What should I do and what UDF do I have to use?!
      Any help will be much appreciated.
    • SRP
      I suggest to check fluent tutorial on FSI: Chapter 28: Modeling Two-Way Fluid-Structure Interaction (FSI) Within Fluent (ansys.com)
      If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
      Hope this helps you
      Thank you
      Saurabh
    • Mahmoud Nassar
      Thank you, this feature is new. This will be very helpful
      on the other hand, my final goal is to couple Piezo+Fluent+Transient Structure.
      Do you have any idea how to impose the oscillation motion within FSI (not the intrinsic FSI)?!
      I will need to couple piezo in the next step
  • The topic ‘Fluid-Structure Interaction for a moving body’ is closed to new replies.
