January 20, 2023 at 10:53 pm
Meng Ke
SubscriberI have imported a design with two ICs on two ends ans ICs are connected through transmission lines. Then I ]have cut this design in the middle so it can be used to run the EM simulation with the IC pins to transmission line traces. However, I can't edit this cutout design, I can't modify or delete the transmission line traces.
1) Got an error messge "No destroyable item(s) were selected" when I selected the line and deleted it.
2) Trying to setup a port at the edge of transmission line edge by selecting the edge of the line and clicking "Port --> create", the error message showed " one or more selected edges are not valid for port membership".Â
Does anyone knows how to fix this?
Thanks in davance.Â
MK
February 6, 2023 at 10:55 am
Praneeth
Ansys EmployeeHi Meng,
Thank you for reaching out to us and we appreciate your patience.
These are my suggestions to hel you troubleshoot the issue:
- Did you verify whether your model is successfully imported into HFSS 3D layout? The way you do it is cross check all the nets.
- Did you run the simulation for the whole model instead of cutting it? Did you succeed in the simulation?
- Can you confirm whether you were able to modify the model before cutting?
Kindly check the above and let us know.Â
All the very best.
Praneeth.
- The topic ‘HFSS 3D Layout – error when editing imported layout design from ODB++ file’ is closed to new replies.
6535
1311
