December 29, 2022 at 2:09 pm
Sushil Sharma
SubscriberI want to analyze Composite Wind turbine blades in fatigue.
December 30, 2022 at 1:29 pm
bhagwantP
Ansys EmployeeHello Sushil ,
Have you used shared topology in modelling?
Looks like error is prompting that there are more than one bodies where topology didn't happened.
Thanks
December 30, 2022 at 6:26 pm
Reno Genest
Ansys EmployeeHello Sushil,
You can vary the thickness by applying prepreg layers as you would do when building the composite layup in real life. One way is to create diifferent element sets for the regions where prepreg layers will be applied. Next, you create many Oriented Element Sets using the different Element Sets. Finally, you can add layers in different regions by selecting the appropriate Oriented Element Sets in Modeling Groups.
Another option is to use selection rules instead of Element Sets.
This is explained in the Ansys Composite PrePost course on the Ansys Learning Hub:
https://jam8.sapjam.com/groups/YHNivy2FbzTCwBmZhqlMGS/overview_page/X59hQ2TTw5kCamrfUyAeA6
If you don't have access to the Ansys Learning Hub, you will find videos on how to build a formula SAE composite chassis with ACP here:
/courses/index.php/courses/formula-sae-composite-monocoque-chassis-analysis/
Let me know how it goes.
Reno.
January 26, 2023 at 4:05 pm
Sushil Sharma
SubscriberThank you
While using the selection rule how to consider the abrupt section change. I want to create sandwich panel "section rule" will create notch in each dividing plane. Does it effect on fatigue analysis of the blade?
January 26, 2023 at 5:06 pm
Reno Genest
You can create abrupt section changes by defining a different number of layers for each oriented element sets. This will lead to ply drop off. Here are 2 ways of doing it:
Splitting the surface in SpaceClaim:
I think the best way of doing it is to slice your surface geometry in SpaceClaim to have all the regions of the surface where you have different layups (different number of plies). You want to split the face without creating new surface bodies:
Then, you create named selections in Mechanical for each region. The named selections will transfer to ACP as element sets. You can then use the different element sets to create the Oriented element sets needed to build the layup. This is the best way because if you refine the mesh in Mechanical, the element sets will update properly based on the named selections in Mechanical. Let me know if you have questions about this process.
Using selection rules:
Using selection rules is the second best option I think. It will keep the regions almost the same when refining the mesh, but you may have some elements that are not picked up by the selection rule and you end up with a jagged region. This may be okay for early design iterations when you don’t know exactly where the boundary of each region will be. So, selection rules is more flexible and allow you to quickly change the boundary of each region.
So, with selection rules you don’t need to split the surface in SpaceClaim and you don’t need to have named selections in Mechanical. I created an example of a square plate with 3 regions (left, middle, and right). Here is the left region selection rule:
Once you created the selection rules, you can create the oriented selection sets:
On the General tab, you select all elements as element set and define the other inputs (point, direction, rosette) as usual. Then, you move to the Rules tab and select the appropriate selection rule for the oriented selection set:
You do the same process for all regions and then you can build the layup (add plies in Modeling Groups):
Then, when you create the solid model, you have drop off options. The default are:
Which leads to the following:
The ply drop offs will happen over the length of your element. So, if you have large elements, the drop off will be smoother and if you have small elements the drop off will be more abrupt.
You can also disable the drop off to get an abrupt drop:
But, this is not a good design; it will lead to stress concentration which is not good for fatigue life. You should have a nice and smooth transition in your composite layup.
I recommend you create a simple plate model like the one above and “play” with the different options and see what works best for you. There are many ways to do things in ACP.
Reno.
January 30, 2023 at 11:04 am
Sushil Sharma
SubscriberThank you, Reno.
I have another question regarding the modeling of the sandwich panel (Foam in between the UD carbon fiber layer). I tried to model it using selection rule. When I try to vary the element thickness by adding the extra layer on the root section, ANSYS adds that section to the previously modeled throughout section. At the root part, my section shows (carbon fiber layer+core+carbon fiber layer+ carbon fiber layer+core+carbon fiber layer). That is, my model has two independent sandwich elements on the root. How can I correct this to my element so that the core will be added to the core part and outer skin to the outer skin part so my model has one (carbon fiber layer+core+carbon fiber layer) with variable thickness?
January 30, 2023 at 7:11 pm
Reno Genest
I am not sure I fully understand the problem. You have 2 sandwiches instead of one? Could you send an image?
How is this part built in real life? How are the layers applied? How is the foam positioned? If you follow the manufacturing procedure in ACP, you should get good results.
The oriented element sets will determine where the foam is located.
Reno.
January 30, 2023 at 7:17 pm
January 30, 2023 at 7:47 pm
Reno Genest
If the composite layers are positioned on top and bottom surfaces of the foam core, you can start by adding the foam core as the first “layer” on the surface. You can apply half the foam core thickness in the “up” direction and half the core thickness in the “down” direction from the surface. Then, you can add the carbon layers on top and bottom surfaces. The result is as follows:
You will need to create double the amount of Oriented selection sets; some for the “up” direction, and others for the “down” direction:
Let me know if this helps or not.
Reno.
January 30, 2023 at 7:59 pm
Sushil Sharma
SubscriberI want to model similar to this but also want to vary the foam's thickness.
January 30, 2023 at 8:15 pm
January 30, 2023 at 8:43 pm
Reno Genest
If your core geometry is complex, you could create the 3D geometry of the foam core in SpaceClaim and then create surfaces on top and bottom faces of the foam core:
You can select "Share" for the share topology setting to have conformal mesh between the solid core and the surfaces. Without "Share", you need to define bonded contacts between the foam core and the surfaces (used to define the carbon layup).
Then, in Mechanical, you can mesh the model and create named selections:
In ACP, you will only see the top and bottom surfaces used to create the composite layup:
But, when you link ACP pre to a Static Structural system, the foam core will show up in Mechanical:
Reno.
January 30, 2023 at 8:46 pm
Reno Genest
Yet another way to do it is to build the composite layup and foam core on a surface like we were doing. Then create a 3D model of the finished composite sandwich, mesh it, and import the 3D solid mesh in ACP to map the composite layup onto the solid mesh. You will find more information about this technique in the help:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_ug/acp_ex_mapped_composite_solid.html
Reno.
January 30, 2023 at 8:51 pm
Sushil Sharma
SubscriberThank you for getting back to me. I will write again about where I will be stuck.
February 4, 2023 at 12:04 pm
Sushil Sharma
SubscriberHello Reno,
I modeled a wind turbine blade using surface elements in space claim. I want to perform a model analysis of the blade, so I import such a model to the design modeler. While opening the model file to generate mesh to my model, some elements are not shown in the window(as shown in the attached screenshot), and some element are extra added to the element tree. How can I solve this issue?
Can you give me any idea about the problem and how to resolve it?
February 6, 2023 at 10:41 pm
Reno Genest
You have to assign a thickness to all surface bodies in Mechanical. You can put 1mm for all surface bodies. You are doing the composite modeling in ACP and so the real thickness will come from the composite layup in ACP.
Note, that you there is no need to import the model into DesignModeler because all the geometry work can be done in SpaceClaim. Make sure the geometry is good in SpaceClaim (no small edges, split edges, etc.). Use the "Repair" and "Prepare" tabs in SpaceClaim:
Reno.
February 8, 2023 at 9:03 pm
Sushil Sharma
I use the selection rule to vary my foam thickness, and I hope it works as I assume too. Now I am stuck in another problem shown in the figure.
I want to wrap my model with four layers of ply from outward, but when I model the ply, it comes inside rather than outside(4 vertical lines on the right side of the outer skin). How can I sift this laminate to the left side of the outer skin?
Thank you
February 8, 2023 at 9:24 pm
Reno Genest
With the Oriented Selection set, you can specify the layup direction to add plies on both sides of the surface (shell elements). You can create another Oriented Selection set and flip the direction to apply a ply on the other side of the surface:
Also, the order of plies in the Modeling group matters; the ply at the top will be the first ply applied to the surface, the second ply in the tree, the second building thickness in one direction (depending on the Oriented Selection set), and so on.
ACP’s modeling philosophy is to follow the manufacturing process. How is this part build in real life? How and where are plies applied? If you follow the manufacturing process in ACP, you should be okay.
Note that Ansys employees are not allowed to upload and dowload files on the forum. If you are a commercial customer, you can submit a service request on the Ansys customer portal and we will have a look at your model. Sometimes it is much easier to troubleshoot this way.
support.ansys.com
Reno.
February 9, 2023 at 12:52 am
Sushil Sharma
SubscriberThank you. It works. Currently, I am using the student version; after some days, my university will provide me with an unlimited version. I try to stick with the manufacturing process, but sometimes the lack of understanding about manufacturing makes it hard to conceptualize.
February 9, 2023 at 1:02 am
Reno Genest
Sounds good. I am glad it works for you. Let me know if you need more help.
Have a good day.
Reno.
March 8, 2023 at 1:21 pm
Sushil Sharma
I have two questions in ACP(pre).
1st, I want to extract the section of my model with different color coding for diverse modeling groups. Is it possible to set the color code in ACP(pre)? I want to set a different color for different modeling groups, as in the attached figure.
2nd, to generate an extruded view of my composite element, I create solid models. Does it affect my plywise analysis later on? Is there any other way to generate an extruded view of the model?
Thank you
- The topic ‘ACP Pre peg Modeling’ is closed to new replies.
6485
