December 5, 2022 at 4:08 pm
Flaminia Piretta
SubscriberI have the Ansys Lumerical 2022 R2.4 version. After generating a mesh I am not able to see it even clicking on 'View simulation mesh', how can I solve this problem?
December 9, 2022 at 1:05 am
Taylor Robertson
Ansys EmployeeThe mesh should be viewable in the 2D cross section window normal to the FDE solver. You can also look at the results after finding modes, if you use (w) hot key you can change to wireframe mode, which should make it visible.
December 9, 2022 at 9:13 pm
Taylor Robertson
Ansys EmployeeThis is actually bug in 2022R2.4, there isn't a workaround in the GUI, but again you can see the mesh in the results.
December 11, 2022 at 11:00 am
Flaminia Piretta
SubscriberThank you for the advice. 'Disabling' the structure I am able to see the mesh, even if it would be better to see both the structure and the mesh simultaneously. I will look at the results as you suggested, thank you.
- The topic ‘Problem with the mesh in lumerical FDE’ is closed to new replies.
3572
1188
1076
1063
952
