Electronics
Electronics
Icepak _Solution termination
    • Venkatesh Chavadi
      I am very new Icepak,
      I am using Ansys Icepak 2022 R2. When i click on solution(Solve icon) i am not getting any message in console and as per ALH it should throw me monitoring plots after solving. Please help with this.
    • Nikhil Tamhankar
      It is possible that there was some issue with getting the license, mesh or solver error which might causing the delay in starting. Please the window console which shows you the solution progress to check for this. Otherwise, check the uns.out file in the project directory and check the lines at the end of this text file for any errors. Please fix those errors and try again.
  • The topic ‘Icepak _Solution termination’ is closed to new replies.
