November 4, 2022 at 8:39 pm
Mehdi Baghaee
SubscriberHi all,
I want to model a delamination in a composite shell. For this purpose I want to use element  shell 281 in ANSYS apdl. I meshed two plate exactly in a same location but with different defined cross-sections. I defined contact between them through preprocessor>modeling>create>contact pair, but when I apply force nothing happens between them (only one-sided deflection appears).
Do you know where the problem is?
Any comment.
November 5, 2022 at 2:04 am
Sean Harvey
Ansys EmployeeHello, Â
Check the contact normals to make sure they shells are oriented properly with normals pointing to each other. This is the first thing I would try.Â
Sean
November 5, 2022 at 12:52 pm
Mehdi Baghaee
Subscriber-
November 6, 2022 at 10:22 pm
Sean Harvey
So, it might be happening is you are loading too quickly and the contact is not detected. You should turn on auto time stepping (autos, on) and then set the NSUBST command so that you are breaking the load into smaller amounts (set min, max, and initial), as what could be happening is the force you apply is enough to push the parts beyond contact (larger than the contact pinball region).
Please try this.
Sean
- The topic ‘How to model a delamination in a composite shell by ANSYS apdl?’ is closed to new replies.
3647
1313
1142
1075
1013
