November 1, 2022 at 11:51 am
164170007
SubscriberI selected kinetic theory in mass diffusivity and thermal diffusion coefficient of mixture template panel but only thermal diffusion coefficient is coming in the plotting panel of XY plot (under species). I used custom defined functions for other variables to calculate, but in that case I dont think its gonna work, correct me if I am wrong.
Thanks in advance.
November 1, 2022 at 1:53 pm
November 1, 2022 at 2:25 pm
164170007
SubscriberHello Rob, As I mentioned I used “kinetic theory” for defining both thermal and mass diffusion coefficient and I want to plot those results. I am sure there would be some provision of plotting those results. I checked fluent theory guide and (see this link https://www.removed! EDIT: Links to rogue copies of Ansys documentation will be deleted, Rob) they mentioned some formula.
Vinay Chandraker
November 1, 2022 at 3:11 pm
Forum ModeratorLooks to be there in my version (2023R1 at present as I'm testing something).
That set of documentation is incredibly out of date, and a technical breach of Ansys copywrite: the link will not be there much longer. If you click on Help in Fluent you'll find the current version.
November 1, 2022 at 8:41 pm
164170007
SubscriberCan you please send me the screenshot of your mixture template and contours panel? ( in which you used kinetic theory for thermal and mass diffusion coefficient)
Vinay Chandraker
November 2, 2022 at 10:06 am
November 3, 2022 at 9:22 am
164170007
SubscriberCan you send the screenshot of contours panel under species tab so that I will get an idea about binary diffusion coefficients of different species.
November 3, 2022 at 9:25 am
Forum ModeratorLook up the thread. My example had 3 species in the mixture. What are you seeing?
November 4, 2022 at 6:39 am
164170007
I am able to see two screenshots. One is for nitrogen material and second is mixture template, but I asked for the contours panel, because when we choose kinetic theory in mixture template for mass and thermal diffusion coefficient it sets automatically and I would like to plot the binary diffusion coefficient for those values which has been set up by fluent automatically. Please see the attached screenshot.
Here only thermal diffusion coefficient is coming but mass diffucion coefficients are not there, when I choose kinetic theory in mixture template.
Vinay
November 4, 2022 at 2:26 pm
November 5, 2022 at 6:16 am
164170007
In your case diffusivities are coming in the contours panel despite choosing kinetic theory, then what would be the issue in my case. (My case is laminar and I have choosen kinetic theory for viscocity, thermal, conductivity of individual species and kinetic theory in mixture template for diffusion coeffcient and thermal diffusion coefficient).
Is it because I am using ansys 2020R2 and you are using newer version?
If its version issue please let me know.
Regards
November 7, 2022 at 11:12 am
Forum ModeratorI'm using 2022R2, and looks like I can pick kinetic theory for components and then again for the diffusivity options.
November 10, 2022 at 1:26 pm
164170007
I am also using ANSYS 20202 R2, then what would be the issue there?
Can I share my case file here, so that you can look? Please let me know.
Vinay
November 10, 2022 at 1:49 pm
Forum ModeratorPossibly, I've not got 20R2 at present so can't check.
If you post files the wider community can have a look. However, Ansys staff are not permitted to open or download anything so I won't be able to do anything.
- The topic ‘How to plot mass diffusivity and thermal diffusion coefficient of gaseous mixtur’ is closed to new replies.
5639
1885
1403
1303
