Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Assign custom profile in Spaceclaim to do beam analysis › Reply To: Assign custom profile in Spaceclaim to do beam analysis
November 1, 2022 at 9:47 am
When you have the full length solid, create two planes where you want the supports and use Split Body to make 3 pieces. Extract each piece into a Beam. Then on the Workbench tab, use the Share button to make sure that the pieces share a nodes at each cut plane. Then in Mechanical, you will have a Vertex to support.
