September 16, 2022 at 12:10 pm
alifian.timur
SubscriberHi, i'm having a problem regarding the Brake Pad Analysis Simulation. when i tried to run the analysis, the solid / brake disc are not rotating within the axis, and result in the sliding of the brake disc, as shown in the image below.
also i found these errors when i finished the simulation :
any help would be much appreciated
September 19, 2022 at 8:34 am
Shakthivel.T.S.
SubscriberHi,
Please can you share the screenshot of your remote displacement (this B.C. applies rotation) details window.
Also, please can you share your PC's RAM capacity.Â
Best Regards,
Shakthivel.T.S.
September 19, 2022 at 1:27 pm
September 20, 2022 at 4:08 am
Shakthivel.T.S.
SubscriberÂ
Hi Alifian Timur,
Please can you upload the model to the below zoho workdrive, to check the set-up:
Link:
https://workdrive.zohoexternal.com/external/894c127788776dc7aea08b222e65fc6b74d1d93e5670ac94b4a68a44fd2bbe59
September 20, 2022 at 11:42 am
alifian.timur
SubscriberHi Mr. Shakthivel.T.S.
I already uploaded the model file to the zoho workdrive link you provided.
Thank you.
June 3, 2023 at 9:07 pm
- The topic ‘Brake Pad Analysis Simulation Problem’ is closed to new replies.
5899
1306
