September 13, 2022 at 8:22 am
ansyskrid
SubscriberHiI want to use Twin Buider and Mechanical in the AEDT suite , however when I run simulation I get the error that these are not in licensing pool.ÂDetails:For Twin Builder : I used Pipe3D static Rom example and Motorcad FMU example. Both give error.Failover feature 'Ansys Twin Builder' is not available.Request name simplorer_twin_models does not exist in the licensing pool.No such feature exists.Featuresimplorer_twin_modelsLicense pathÂÂFor mechanical: Motor HousingÂÂÂ Â [error] Failover feature 'Ansys Mechanical Pro' is not available. Request name mech_1 does not exist in the licensing pool. No such feature exists. Feature:Â Â Â Â mech_1 ; FlexNet Licensing error:-5,147 (10:16:12 AMÂ Sep 13, 2022)Â Â [error] Simulation was terminated by license error.ÂÂ Before running the examples I did save them in local drive.
Pro, peremium option is on
Is there any other setting that needs to be set before running these?
I have no issue in running Maxwell and Icepak(which i use most frequently)
Also, Can someone let me know the commands for run in command prompt to inquire which license I have and what can be run with those licenses?
Thanks -
September 14, 2022 at 10:49 am
Forum ModeratorTwin Builder needs a separate licence. The Mechanical solver is also a separate licence to the Electronics software (Maxwell, Icepak etc). You need to open the licence manager to see what's available, do you have a local licence or link to the campus network?
- The topic ‘Does Twin Builder and AEDT Mechancal need special extra Licence?’ is closed to new replies.
Ansys Innovation Space
1414
1231
1118
1015
