August 5, 2022 at 11:59 am
atfkerem76
SubscriberHello. I'm simulating an optical antenna structure. There is a fiber in the center of the structure.
I'm using a 3D monitor as it seems in the below image.
The source wavelength is between 360-345nm's and it's propogating along the "x" axis. After the simulation it shows me the E-field results on "z" axis as "slices". There are 53 datas in this index. And it changes depending on the position of slices.
I'd like to calculate average E-field on it's surface in "z" axis. Is there a way to do that? Thanks.
August 5, 2022 at 7:48 pm
Guilin Sun
Ansys EmployeeDefinitely, you can. However, it seems you are simulating a fiber cavity? where the source is located? inside the cavity or outside? dipole or mode source or Gaussian source.
Once you get the E-field from the 3D monitor, you can integrate along Z only. related scripts are
getresult eg E3D=getresult("monitor","E")
dot operation Ez3D=E3D.Ez #Ez
E2=E3D.E2; # intensity
z=E3D.z
integrate eg integrate(E2,3,z);
Please search online if you want to get more informtation for each script.
August 6, 2022 at 8:31 am
atfkerem76
SubscriberActually, not the cavity. There is an actual fiber there but it's hard to see a bit I think ? source is outside of the structure, it's located at x:-600nm , y: 0nm, z: 600nm. It's a plane wave source. Fiber is at the origin of simulation which is x:0, y:0 and z:0. Whole simulation area geometry is xspan: 2000nm, yspan: 2000nm and zspan: 2000nm.
I used the script you mentioned and attached the integration result to "last_result" variable. Then I visualized it. Here is what I get:
I'm using 21 steps for the frequency band. When tried to see actual 3D monitor results, it gave me 53 datas for each frequency step. Now I can monitorize just frequency responses for "z" axis. I think this makes sense.
August 8, 2022 at 2:54 pm
Guilin Sun
Ansys EmployeeWhere the device has two more material interfaces alog the propagation axis, it can be called "cavity". I am glad to can visualize the result using script.
August 8, 2022 at 4:02 pm
atfkerem76
SubscriberOh I see... Sorry I'm still learning.
I have a few more questions though.
First, with the same script, I tried to visualize the average E-field values for "x" axis and I get the image below. It actually seems that it shows the fiber cavity, but I didn't understand why it shows like there two fibers?
Second, after the simulations I was able to see the E-field results like "1.23,1.03" etc. Like the first image I've sent. But after the integration process, when I tried to visualize results, it was like "1.14e-06, 9.92e-07". Like previous image I've sent. Why is it shows like this? And since the source's amplitude was "1", can I say there are some amplifications happens in some places on fiber?
August 8, 2022 at 4:34 pm
Guilin Sun
Ansys EmployeePlease use dataset to create the image data so you will know which axis represents what quantity: https://optics.ansys.com/hc/en-us/articles/360034409554-Introduction-to-Lumerical-datasets
There is no Amplification for linear simulation, as you can measure the transmission and reflection are smaller than 1. However, the electric field can be enhanced, due to interference, diffraction and reflection (forming cavity standing wave).
Please note, you can normalize the intensity by dividing your current result with integrate(E2/E2,3,z). This way you can get relative field strength to the source amplitude. As you know the integration creates an additional length dimension.
Since this is cylindrical device, it has symmetry so you see two "bars". SO I guess the index_2 is along its diameter, index_1 is along its length? from your first image, the strong E-fields are not at the center.
It is not supprising to me, as you are simulating a cavity, with a plane wave excitation. Do you use TFSF local plane wave, or regular plane wave with periodic boundary condition so you are simulating periodic array? if your device is a single section for fiber, please use TFSF: https://optics.ansys.com/hc/en-us/articles/360034902133-Understanding-source-normalization-in-the-TFSF-source
If you use regular plane wave with PML, the PML will truncate the plane wave and then diffraciton occurs:
https://optics.ansys.com/hc/en-us/articles/360034382874-Understanding-field-truncation-issues-with-finite-sized-plane-wave-sources
I guess in experiment you mayuse a gaussian beam, which has finite size, even though its beam waist is larger than the finer cross section. I think TFSF is a better choice for such case.
August 9, 2022 at 8:50 am
atfkerem76
SubscriberI see. Many thanks for all these information. Learned a lot from this.
- The topic ‘Average E-field calculation on a fiber surface’ is closed to new replies.
6369
