July 17, 2022 at 3:31 am
mdmech.mech
SubscriberHello Sirs,
I have downloaded ANSYS 2022 R2 student version from ANSYS. After installing it, when i trying to start ANSYS Mechanical APDL, it is showing a error "The procedure entry point_svml_hypot4_19 could not be located in the dynamic link library E:\Progem File\ANSYS Student\v222\ANSYS\bin\winx64\Cadoekernel.dll" when i click ok it started to show the similar error with "cadoe_algoriths.dll" , "Cadoelegacy.dll" and so on..... I could not able to start the Workbench solver module also.
I have tried to reinstall with some other drive, Disable anti virus. But nothing helped me. Can any one please resolve this issue. Attaching screen shot.
Thanks
July 20, 2022 at 2:27 pm
Ashish Khemka
Forum ModeratorHi,
This is a duplicate post. You already have created one more query.
Ashish Khemka
July 23, 2022 at 5:07 am
mdmech.mech
SubscriberOk Sir, Any solution from ANSYS, for this issue, please reply
August 7, 2022 at 9:00 pm
mrife
Ansys EmployeeHi @mdmech.mech Well this is a new one. Please open a dos command window; issue the command set; and copy paste the "a" listings i.e. any environment variable that starts with the letter a. And the PATH environment variable. Â
Next search C:\Windows\System32 and C:\Windows\SysWOW64 for the dll mentioned in the error message. If found try renaming by changing the dll extension to dllold. Then try starting up MAPDL.
- The topic ‘ANSYS APDL – Not Opening – Free Student Version’ is closed to new replies.
5874
1306
