Marangoni Shear Stress
    • pourya.heidari
      DEAR all
      I want to simulate the laser welding with the FLUENT. I just activate the solidification and melting (without VOF). I face a problem to import the Marangoni effect into my simulation. In the BOUNDARY CONDITION (MARANGONI STRESS), I found the formula for surface tension gradient variation base on the temperature. Since I could not import the surface tension gradient by UDF in the MARANGONI STRESS, I try to import this effect by UDF in the SPECIFIED SHEAR. I attach the formula for this part and shot screen of specified stress.
      To be honest, I do not know which Macro I should use to write this formula. I try DEFINE_PROPERTY and DEFINE_PROFILE. In my UDF, I consider the surface tension graidient as a constant. Everytime I run this code, Fluent would close. It is very painful. Please help me to find the error of this UDF.
      Here you can find the UDF that I wrote for this part.
      DEFINE_PROFILE(marangonix, t, i)
      face_t f;
      cell_t c;
      Thread *tc;
      real grad_temp, gama_temp;
      begin_f_loop(f,t)
      c=F_C0(f,t);
      tc = THREAD_T0(t);
      //tc=F_C0_THREAD(f,t);
      grad_temp= C_T_G(c,tc)[0];
      gama_temp=-0.00043;
      F_PROFILE(f,t,i)=gama_temp*grad_temp;
      end_f_loop(f,t)
      DEFINE_PROFILE(marangoniy, t, i)
      face_t f;
      cell_t c;
      Thread *tc;
      begin_f_loop(f,t)
      c=F_C0(f,t);
      tc = THREAD_T0(t);
      grad_temp= C_T_G(c,tc)[1];
      gama_temp=-0.00043;
      end_f_loop(f,t)
      DEFINE_PROFILE(marangoniz, t, i)
      face_t f;
      cell_t c;
      Thread *tc;
      begin_f_loop(f,t)
      c=F_C0(f,t);
      tc = THREAD_T0(t);
      grad_temp= C_T_G(c,tc)[2];
      gama_temp=-0.00043;
      end_f_loop(f,t)
    • RK
      What is the error message that you are getting? It would be sometimes easier to debug knowing the error message and where to look at.
      • pourya.heidari
        Thank you Ruhal.
        It gives the following error and then it close the FLUENT in few seconds. I feel deep pain with this error. I do not know why it closes the software.
    • RK
      This could be a systems related issue, can you please try to run it without UDF to see if the simulation runs fine? We could then narrow down the issue to UDF.
      • pourya.heidari
        Dear Rahul
        I tried it without UDF. It works fine, and the results are reasonable. I am sure that the error is because of the UDF. I can not debug the UDF.
    • DrAmine
      Check if you can access the temperature gradients first. My question: why are'nt you using the default Marangoni Stress Wall BC?
  • The topic ‘Marangoni Shear Stress’ is closed to new replies.
