Ansys Learning Forum Forums Discuss Simulation General Mechanical Coordinate system at each point of a surface Reply To: Coordinate system at each point of a surface
ErKo
HI
See the nrotat command that rotates the nodal coordinate system as needed. There is though a limit on how many coordinate systems you can define I imagine, so if you have 1 million nodes and need so many coordinate systems .
This post is also useful if you use WB mechanical
Hope this helps
