Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Cannot open “Edit object” window for simulation objects with Script tabs in Lumerical FDTD › Reply To: Cannot open “Edit object” window for simulation objects with Script tabs in Lumerical FDTD
July 23, 2021 at 3:51 pm
Thank you for your reply.
Where can I find the ini file that I should try deleting? The link you provided points to another link with the location of the file but it when I follow it I am met with this message:
Thanks again!
