F1 front wing simulation problem
    • EmmanuelBiocca
      Hello everyone.
      I am running several simulations on a formula 1 front wing. I have done several simulations at different heights from the ground without any kind of problem. Now I'm just trying to rotate the wing a few degrees, keeping all the other parameters of the simulation fixed, but after a few interactions the simulation fails. What could be the problem?
    • Keyur Kanade
      Can you please check if you can run in serial mode or parallel mode?
      Also make sure you are using recommended hardware as mentioned in the following link.
      Platform Support and Recommendations | Ansys
      If not, this could be licensing issue. Please create a post under installation category.
      Regards Keyur
  • The topic ‘F1 front wing simulation problem’ is closed to new replies.
