May 16, 2022 at 9:36 am
GridMan
SubscriberI'm trying to use solution steering to speed up my calculations. In the steering setting, there are two ways to update the CFL number in stage2, namely immediately and after. What is the difference between these two?
May 16, 2022 at 9:58 amRob
Forum ModeratorIf you look at the panel there's a Help button. Click that and see what it says.
May 17, 2022 at 1:41 amMay 17, 2022 at 8:54 amRob
Forum ModeratorIt's what it says. Immediate will adjust the courant number every iteration, after will be after another 20 (in the panel you posted) iterations. When it works you'll see a residual plot that resembles steps going down.
May 18, 2022 at 1:51 amGridMan
SubscriberThanks for your answer,if immediate is to update the CFL number every iteration, what does the following "Courant number update interval"mean?Why do I still need to set a Courant number of update steps´╝ƒ
May 18, 2022 at 12:30 pmRob
Forum ModeratorPass, it may just be a glitch on the panel. I've never used the function.
May 19, 2022 at 8:03 amGridMan
SubscriberThank you!
Viewing 6 reply threads- The topic ‘Questions about Fluent solution steering’ is closed to new replies.
4863
1587
1386
1242
