April 28, 2022 at 12:52 pm
aitor.amatriain
SubscriberAfter installing 2022R1 version, I have not had any problem for some days, but yesterday I noticed a problem in SpaceClaim 2022R1: When selecting one of the tools from the menu (Display, Assembly, Measure....) then all of the options are gone.
For example, the "Pull" tool, the following should appear:
April 28, 2022 at 2:02 pmRob
Forum ModeratorMy guess would be graphics, do any of the other functions do the same?
April 28, 2022 at 3:25 pmaitor.amatriain
SubscriberThe problem is the same in all functions, and it started suddenly (no after updating the computer, for example). In 2020R2 I do not have that problem.
April 28, 2022 at 4:07 pmRob
Forum ModeratorIf it's sudden then find the %appdata% folder and move the Ansys 22R1 folder(s). Otherwise it could be a Win10 update? My home PC has some of those set as automatic and some as manual updates.
Check the SpaceClaim section too - I've got a couple of versions with separate folders. As I also have some fairly alpha-builds I can never be sure what installs when with some releases.
April 29, 2022 at 8:17 amaitor.amatriain
SubscriberThank you for your answer, Rob.
I was working in that moment and I do not think that something was installed.
The C:\Users\User\AppData\Local\Ansys\v221 folder is empty
The C:\Users\User\AppData\Roaming\Ansys\v221 and C:\Program Files\ANSYS Inc\v221\scdm folders have many files and I do not know what I have to look for
April 29, 2022 at 1:27 pmRob
Forum ModeratorAppdata is a settings storage so just rename as _old
C:\Program Files\ANSYS Inc\v221\scdm is probably the SpaceClaim folder so is a little more important! Leave that one alone or we'll need to fix the mess.
April 29, 2022 at 2:14 pmGeorge Karnos
Ansys EmployeeTry renaming the %APPDATA%\SpaceClaim directory to SpaceClaim.old
April 29, 2022 at 3:38 pmaitor.amatriain
SubscriberThere is no directory with that name in my computer. In AppData folder there are just three folders: Local, LocalRow, and Roaming. The same applies to the computer that works okay.
April 29, 2022 at 3:59 pmRob
Forum ModeratorLook in those.
April 29, 2022 at 4:09 pmGeorge Karnos
Ansys EmployeeApril 30, 2022 at 1:36 pmaitor.amatriain
SubscriberIt worked! Thank you so much and !
Out of curiosity (and to add some knowledge to my limited knowledge about these topics): What was the problem and why the renaming of those folders has solved it?
May 2, 2022 at 12:56 pmGeorge Karnos
Ansys EmployeeExcellent News!
These folders hold configuration files for SpaceClaim.
Something must have been corrupted in a configuration file.
May 3, 2022 at 2:14 pmaitor.amatriain
SubscriberThank you!
Viewing 12 reply threads- The topic ‘Lack of features in SpaceClaim locking layout’ is closed to new replies.
4618
1530
1386
1210
