April 16, 2022 at 4:30 amRajat Kumar SinhaSubscriber
Hey, I am trying to find the effective index of a mode inside the waveguide which has a grating on top. The waveguide looks something like
April 25, 2022 at 11:25 pmKyleAnsys Employee
The FDE solver in MODE calculates waveguide modes assuming that the refractive index cross-section is constant along the direction of propagation, for straight, bent and helical waveguides. If there is a grating this means the index cross-section is changing, so FDE can't be used. For this reason, typically FDTD or EME would be used for simulations with gratings. We have some examples of grating and photonic crystal simulations available in our Application gallery here that might be helpful for you: https://support.lumerical.com/hc/en-us#app-anchor
Viewing 1 reply thread- The topic ‘Effective index of the mode inside waveguide with grating on top’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
- Absorption cross-section of AuNR excited by prism-based TIR
Top Contributors-
1301
591
544
524
366
