March 11, 2022 at 5:26 pm
Aimran96
SubscriberHi all. I am trying to conduct a transient structural analysis with a given stress-time signal. Given the data is in around 66k timesteps. I tried to write them in .xml data and import them in ansys but there are some datas which are highlighted yellow and become the same value which are actually not. Some data are read in two decimal points instead. Is there a way to solve this problem? To change and type each timesteps data, I would find them quite disastrous. The same problem occurs when I am importing data for random vibration analysis with .xml file. I am currently using ansys acadamic research license.Â
Thank you in advance for your help.
March 15, 2022 at 3:04 pmChandra Sekaran
Ansys EmployeeHave you tried just cutting and pasting from Excel sheet? May be that is a good workaround?
March 16, 2022 at 11:58 pmAimran96
SubscriberI have done it and it works. Thanks. Another question though, is there a way that I could reduce the size of .rst file? The current one I have is at 43GB which is quite big.I just want the results for stress in transient analysis only, so that I can use them for other FE-Solver which is FEMFAT. Is there a method in command APDL to do this?
Viewing 2 reply threads- The topic ‘Problem by importing .xml file into load-time history in Ansys’ is closed to new replies.
1997
897
599
591
444
