February 18, 2022 at 9:58 pm
fz.erraghroughi
SubscriberHello everyone!
I want to use ICEM CFD to generate a structural mesh of my geometry. However, ICEM is very slow I can't work with it! I can't even move my geometry. Is there any way to solve this problem?
Thanks in advance.
Regards.
February 19, 2022 at 4:03 pmpeteroznewman
SubscriberWhy do you want to use ICEM CFD if it is very slow? You say you want a structural mesh, have you tried a Mechanical Model component for meshing? This is the same software as the Mesh component used to generate a mesh for Fluent.
February 19, 2022 at 4:54 pmfz.erraghroughi
SubscriberThank you for the reply!
I actually failed to mesh my geometry using Mechanical, I am about to mesh A bend pipe with a rib in the extrados of the bend. I tried the multizone method, I split my geometry into several parts but nothing is worked so I decided to use the icem maybe it will generate the hexahedral mesh. Unfortunately, Icem refuses to work correctly for me!
here is my geometry:
February 20, 2022 at 2:43 pmpeteroznewman
SubscriberIf you put this geometry into a Geometry cell in Workbench, use the File Archive to make a .wbpz file and attach that to your reply and say what version of ANSYS you are using. I will give it a try.
February 20, 2022 at 5:24 pmfz.erraghroughi
SubscriberSorry for the late reply! please find attached the geometry. I am using Ansys 2019 R1.
Thank you!
February 21, 2022 at 12:30 ampeteroznewman
SubscriberFebruary 21, 2022 at 3:03 amfz.erraghroughi
Subscriber@peteroznewman Thank you so much!
"I can show you how I did this in SpaceClaim if you want to schedule time for a video chat." yes, could you please send me a private message to schedule the time? and could you please tell me which version of Ansys you used?
I tried to do the same slice in the design modeler when slicing at the diameter of the cut and at the edges of the rib I got those surfaces!
here is the generated bodies:
the mesh failed to generate the structured mesh. I think the surfaces generated are the source of this bad mesh.
February 21, 2022 at 4:08 ampeteroznewman
SubscriberI used ANSYS 2022 R1 to do the slicing in SpaceClaim, but it should work the same way in 2019 R1.
There are no private messages on this site, so to schedule a meeting, you would post an email address. Note that you can edit your post for 1 hour after posting. I check for new notifications on the site each morning around 8 AM EST. You can see who is online by clicking View Profile. If you see I am online, you can post here and if you type the notification will work (what you did above is not valid for notifications). Once you confirm I have replied, you can submit a post with your email, and delete it within the hour. If you miss the cutoff, you can ask the admin to delete your email address.
February 21, 2022 at 1:00 pmfz.erraghroughi
February 21, 2022 at 1:07 pmpeteroznewman
SubscriberGood morning.
February 21, 2022 at 1:10 pmfz.erraghroughi
SubscriberGood morning!
February 21, 2022 at 1:11 pmpeteroznewman
SubscriberOkay, thanks.
February 21, 2022 at 1:13 pmfz.erraghroughi
SubscriberI am waiting for your email. Thank you !
Viewing 12 reply threads- The topic ‘is there any way to accelerate the manipulation in ICEM CFD ?’ is closed to new replies.
4492
1494
1376
1209
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
