February 3, 2022 at 2:48 pm
Rwinton
SubscriberFebruary 8, 2022 at 9:35 pmANSYS_MMadore
Forum ModeratorPlease share complete text of the error you are encountering.
February 9, 2022 at 2:11 pmRwinton
SubscriberThat message is the only thing that appears on the startup of the application.
February 9, 2022 at 4:15 pmANSYS_MMadore
Forum ModeratorWhat you need to do is launch the Client Licensing Settings utility, making sure to use right-click -> run as administrator. Then you can enter the right license server information in the form and hit Save. See if that helps.
Viewing 3 reply threads- The topic ‘ANSYS License Error – Failover Feature’ is closed to new replies.
4939
1639
1386
1242
