January 16, 2022 at 12:58 pm
avitalmic
SubscriberJanuary 17, 2022 at 2:26 pmNikhil N
SubscriberHello,
Can you please elaborate more on the issue or the error you are encountering?
Also, make sure you enter correct start and end frame (which is 0 in the attached image). Also check if the files (.hsf and .cxa) saved are for the selected animation sequence.
Nikhil
January 18, 2022 at 12:32 pmavitalmic
SubscriberHi once the simulation has done, I tried to play the animation but as you can see I cant change anything on the setting window. It seems like there's no data to play but I do see the files in the folder (yes, its the correct files..)
January 19, 2022 at 8:20 amKishan Konannavar
Ansys EmployeeHello
Maybe you can refer to this video if you haven't already. Hope it helps.
ANSYS Fluent: Scene and Animation Creation - YouTube
Regards
Kishan
January 25, 2022 at 6:40 amNikhil N
SubscriberHello,
Can you share these two things:
1: Screenshot of the 'Animation Definition' window. Make sure you keep the required one selected.
2: Screenshot of .cxa file (First few lines would do).
Nikhil
January 25, 2022 at 7:48 amAmine Ben Hadj Ali
Ansys EmployeeOpen a new Fluent session do load any case file just read the animation file there. Will that work?
January 27, 2022 at 12:48 pmavitalmic
Subscriberthanks everyone! I did again all the steps and run the simulation again and now it works.. I dont know what was the reason it didnt wotk the first time
January 31, 2022 at 9:09 amAmine Ben Hadj Ali
Ansys Employeeprobably the file (*cxa) was corrupted. Anyway: you are now over it!.
Viewing 7 reply threads- The topic ‘can’t play the animation’ is closed to new replies.
5019
1708
1387
1248
