January 12, 2022 at 7:23 pm
C_Mortensen
SubscriberI am trying to apply a displacement to the top of my foldcore model, as shown in the picture below, however, as I do so and run the simulation I get an error that says, "An error occurred when the post processor attempted to load a specific result. Please review all messages." As I go look at this error it tells me that there needs to be a "post processing required" What is post processing and how do I fix this.
The foldcore model is taken from ACP pre with carbon fiber as the material
January 13, 2022 at 10:34 pmChris Quan
Ansys EmployeeThe Solution Information under Solution in Tree Outline has the check mark, which indicates that the simulation has been done successfully.
You need to look at the Total Deformation to make sure the Display Time is set to Final. If not, enter 0 on Display Time to reset it to Final. Then you can right click Solution to evaluate the results.
Viewing 1 reply thread- The topic ‘post-processing required’ is closed to new replies.
6675
1313
