January 10, 2022 at 1:06 pm
Psyne
SubscriberHello,
I am currently using an academic version of fluent to run simulations on HPC. Through the simulations I am exporting .cgns data and each time the simulation is interrupted due to "Unable to get license for VKI Library". (see the attached image)
February 1, 2022 at 2:06 pmGeorge Karnos
Ansys EmployeeWhat version are you running?
2021 R2?
Do you see the issue if you do not export cgns data?
February 1, 2022 at 2:18 pmGeorge Karnos
Ansys EmployeeCan you please post a license status as to what licenses are available on the license server?
Please post a screen shot as we are not permitted to open files.
February 1, 2022 at 2:37 pmPsyne
I am using the 2021 R2 version. I used to see the problem when exporting cgns data but I got arround it by exporting ascii files.
I have an academic license for fluent but I can't send you a screenshot as I silently installed fluent and directly filled in the command line the license server.
But what I am certain is that I have an academic version with enough CPUs and also an HPC license.
Thank you for your answer.
Viewing 3 reply threads- The topic ‘VKI license issue on Academic licence of Fluent on HPC’ is closed to new replies.
6745
1324
1047
