January 6, 2022 at 2:03 am
pyg0511
SubscriberHi all,
I got an error regarding importing CAD file into Fluent meshing.
hat I did is to make a model using SpaceClaim and imported that file into Fluent meshing so that I could make an appropriate number of meshes and run a simulatison. But, the problem is when I import model file, I got an issue shown below.
January 6, 2022 at 2:07 ampyg0511
SubscriberI don't know why there are lots of typos. But maybe can understand what I am dealing with.
Best wishes.
Younggi
January 6, 2022 at 6:03 amKeyur Kanade
Ansys EmployeePlease check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
The error may be due to CAD configuration is not done correctly.
You can check following links
CAD Configuration Manager not installed ÔÇö Ansys Learning Forum
CAD Configuration Manager (ansys.com)
Regards Keyur
January 6, 2022 at 9:39 amRob
Forum ModeratorCan you also post the rest of the error message. I've seen a licence problem with SpaceClaim, but Step files import OK.
Viewing 3 reply threads- The topic ‘Error in CAD import’ is closed to new replies.
4858
1587
1386
1242
