Ansys Products
Ansys Products
Infiniband Error in fluent
    • marine_engine
      After installing ANSYS Fluent on Centos 8.3,
      If infiniband choosed in Fluent , the following error will occur.
      The same phenomenon occurs even if Fluent install it repeatedly.
      how to resolve this problem?
      /ansys_inc/v212/fluent/fluent21.2.0/bin/fluent -r21.2.0 3ddp -pinfiniband -host -alnamd64 -t128 -mpi=intel -cnf=/home/e102588/Downloads/128.txt -path/ansys_inc/v212/fluent -ssh -cx rndb0:32989:37435
      Starting /ansys_inc/v212/fluent/fluent21.2.0/lnamd64/3ddp_host/fluent.21.2.0 host -cx rndb0:32989:37435 "(list (rpsetvar (QUOTE parallel/function) "fluent 3ddp -flux -node -alnamd64 -r21.2.0 -t128 -pinfiniband -mpi=intel -cnf=/home/e102588/Downloads/128.txt -ssh") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "128") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) "/ansys_inc/v212/fluent") (rpsetvar (QUOTE parallel/hostsfile) "/home/e102588/Downloads/128.txt") )"
             Welcome to ANSYS Fluent 2021 R2
             Copyright 1987-2021 ANSYS, Inc. All Rights Reserved.
             Unauthorized use, distribution or duplication is prohibited.
             This product is subject to U.S. laws governing export and re-export.
             For full Legal Notice, see documentation.
      Build Time: May 28 2021 13:48:13 EDT Build Id: 10201
      Host spawning Node 0 on machine "rndb0" (unix).
      /ansys_inc/v212/fluent/fluent21.2.0/bin/fluent -r21.2.0 3ddp -flux -node -alnamd64 -t128 -pinfiniband -mpi=intel -cnf=/home/e102588/Downloads/128.txt -ssh -mport 172.132.20.10:172.132.20.10:35801:0
      Starting /ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi/lnamd64/intel/bin/mpirun -f /tmp/fluent-appfile.e102588.614704 --rsh=ssh -genv I_MPI_FABRICS shm:dapl -genv I_MPI_DAPL_UD enable -genv I_MPI_FALLBACK_DEVICE disable -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_ADJUST_REDUCE 2 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_ADJUST_BCAST 1 -genv I_MPI_ADJUST_BARRIER 2 -genv I_MPI_ADJUST_ALLGATHER 2 -genv I_MPI_ADJUST_GATHER 2 -genv I_MPI_ADJUST_ALLTOALL 1 -genv I_MPI_ADJUST_SCATTER 2 -genv I_MPI_ADJUST_SCATTERV 2 -genv I_MPI_ADJUST_ALLGATHERV 2 -genv I_MPI_ADJUST_GATHERV 2 -genv I_MPI_PLATFORM auto -genv I_MPI_DAPL_SCALABLE_PROGRESS 1 -genv PYTHONHOME /ansys_inc/v212/fluent/fluent21.2.0/../../commonfiles/CPython/3_7/linx64/Release/python -genv FLUENT_PROD_DIR /ansys_inc/v212/fluent/fluent21.2.0 -genv KMP_AFFINITY disabled -genv LD_PRELOAD /ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi/lnamd64/intel/lib/libstrtok.so -genv TMI_CONFIG /ansys_inc/v212/fluent/fluent21.2.0/multiport/mpi/lnamd64/intel/etc/tmi.conf -machinefile /tmp/fluent-appfile.e102588.614704 -np 128 /ansys_inc/v212/fluent/fluent21.2.0/lnamd64/3ddp_node/fluent_mpi.21.2.0 node -mpiw intel -pic infiniband -mport 172.132.20.10:172.132.20.10:35801:0
      [0] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [2] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [4] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [5] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [7] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [8] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [9] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [11] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
      [12] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
    • ANSYS_MMadore
      Can you please try using a different mpi or interconnect? Try -mpi=intel2019 if that does not work try using ethernet -pethernet rather than -pinfiniband, as it appears to be an IB issue at first glance.
  • The topic ‘Infiniband Error in fluent’ is closed to new replies.
