Electronics
Electronics
How to obtain two way coupling of electromagnetic (2D) and structural analysis (2D) in workbench?
    • agarwa20
      I am getting the coupling from EM to structural but not from structural to EM.
    • Praneeth
      Did you try adding the feedback iterator in the workbench?
      Best regards.
    • agarwa20
      Hi I tried it. As far as I checked the feedback iterator works only with 3D geometry case. Is there some other way to get the coupled results between EM and structural analysis?
      Thanks.
      Best regards.
    • HDLI
      Could you try to use Maxwell 2D and Mechanical 3D? I am not sure what the mechanical 2D presents and if the 2D model work in the 2-way coupling. Thanks.
      HDLI
  • The topic ‘How to obtain two way coupling of electromagnetic (2D) and structural analysis (2D) in workbench?’ is closed to new replies.
