Applying cyclic symmetry in Explicit dynamic analysis
    • Ranjan13
      Dear all!
      I want to simulate the compression test of the below structure using Explicit dynamic analysis.
    • Ashish Khemka
      Please refer to the following link for Symmetry in Explicit Dynamics Analysis:
      2.7.1. Explicit Dynamics Symmetry (ansys.com)
      By the way for the compression test - is it a very short duration (say a fraction of a second) test? If yes then Explicit is fine, otherwise, you may use a Static Structural analysis.
      Regards Ashish Khemka
    • Ranjan13
      Thanks a lot, Ashish for the reply!!
  • The topic ‘Applying cyclic symmetry in Explicit dynamic analysis’ is closed to new replies.
