November 12, 2021 at 1:01 pm
Pukmester
SubscriberI need to do Transient thermal electrical analysis, can it done in Ansys Workbench.
Best Regards
November 12, 2021 at 5:38 pmErKo
Ansys EmployeeYes, but we need to add a apdl command snippet to the thermal electric system in Workbench.
The command used is:
antype,4 ! transient
timint,on
See these commands for more info
All the best
November 23, 2021 at 5:29 pmPukmester
SubscriberThank you for your reply
but the model cant solve
can you tell me where is the problem
Thanks in Advance
November 24, 2021 at 2:07 amdinhan0394
SubscriberHe recommends 2 commands, but you use more and type it wrong
Recommend:
timint,on
You type:
/SOLU
Antype,TRANS
Time, On
SOLVE
Repair them you will get result.
November 24, 2021 at 10:15 pmPukmester
SubscriberSame problem
November 25, 2021 at 1:43 amNovember 25, 2021 at 6:19 amPukmester
SubscriberCould the reason be the capabilities of my pc
November 25, 2021 at 6:44 amNovember 25, 2021 at 7:24 amErKo
Ansys Employee- you are not following ahat says - so use only this:
timint,on
So remove /SOLU not needed and you can not use SOLVE command again since Mech. will be solving anyhow.
If you still get an error - go to Solution Information and in the Solver Output and find the error (ctrl+f and search for error). Post the error message in this discussion.
All the best
Erik
June 27, 2022 at 11:15 amPukmester
Subscriber@Erik KostsonÂ
how can i add different load after different timeÂ
etal.  at the first the load 1000 kA after one hour 3000KA etc.
thanks in advance
Viewing 9 reply threads- The topic ‘How can I perform a transient thermal electric Simulation in ANSYS?’ is closed to new replies.
6064
