November 9, 2021 at 8:44 am
KMoula30
SubscriberNovember 11, 2021 at 10:06 amNKC
Forum ModeratorHi @KMoula30 The cause, which is the current in the coil is counterclockwise.
So, the effect will be in a clockwise direction.
If you are applying Right hand thumb rule, it will apply only to the coil, and its filed as the source current is flowing in the coil only.
Regards Navya
November 11, 2021 at 3:22 pmKMoula30
SubscriberWhy is that?
In the sheet the B is in +x direction so if we apply right hand rule for the B the current must be counter clockwised
Viewing 2 reply threads- The topic ‘Simple eddy current simulation eddy current opposite direction’ is closed to new replies.
Innovation SpaceTrending discussions- Three-Phase Voltage Imbalances in dual stator electric generator
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
Top Contributors-
4612
1515
1386
1209
