Assigning HSFLD242 elements to enclosed surfaces using APDL command objects in Workbench
    • joekerch
      I am trying to simulate force on a diaphragm that results in a change in pressure of a chamber. I am able to set up this simulation without any fluids inside of the chamber and it returns deformation results. The goal is to place a trapped fluid inside of this chamber so that the change in force on the diaphragm results in a change in pressure of the fluid as the diaphragm deforms slightly.
      I am now working to assign HSFLD242 elements to the inside walls of the chamber under the diaphragm. I am not familiar with APDL (trying to learn) and am attempting to add the HSFLD242 elements using a commands object in the workbench static structural tree. I have edited the code from this example to fit my project the best that I could. Here is the edited version, where the inside walls of the chamber are named "walls'
      ! Be careful with UNITS because of the material propertites. <<<==========
      ! It is assumed that NO SYMMETRY effects are in this model.
      fini
      /prep7
      *get,typemax,ETYP,,NUM,MAX ! max defined element type
      *get,realmax,RCON,,NUM,MAX ! max defined real constant
      *get,mat_max,MAT,,NUM,MAX ! max defined material
      *get,nodemax,NODE,,NUM,MAX ! highest numbered node in model
      ! Create a new higher number for element type, real, and material
      newnode=nodemax+1000 ! number for pressure node for HSFLD242
      newnumber=typemax+1
      *if,realmax,ge,newnumber,then
      newnumber=realmax+1
      *endif
      *if,mat_max,ge,newnumber,then
      newnumber=mat_max+1
      *endif
      et,newnumber,HSFLD242 ! 3-D Hydrostatic Fluid Element
      keyopt,newnumber,1,0 ! UX, UY, UZ, plus HDSP at pressure node
      keyopt,newnumber,5,1 ! Fluid mass calculated based on the volume of the fluid element
      keyopt,newnumber,6,1 ! Incompressible
      mp,dens,newnumber,1.0e-9 ! Density of Water, kg/mm^3/1000
      ! Ignoring thermal expansion in this example
      ! Ignoring TB,FLUID in this example
      r,newnumber ! Ignoring Reference pressure for compressible gas
      type,newnumber
      mat,newnumber
      real,newnumber
      cmsel,s,walls ! Select nodes on interior
      esln ! Select elements that touch these nodes
      n,newnode,0,0,0.07 ! Pressure node at 0,0,400 (automatically moved to centroid?)
      ESURF,newnode ! ESURF HSFLD242 elements over solid element faces
      ! Extra node “newnode” with ESURF with HSFLD242
      allsel
      fini
      /solu ! return to solving
      When I hit solve, the program does not converge and it returns errors. Any help on how to assign the HSFD242 elements to this would be appreciated, I can share more from the workbench project if needed.
    • ErKo
      Hi
      Can you please include the error message found in the solution information?
      Thank you
      Erik
  • The topic ‘Assigning HSFLD242 elements to enclosed surfaces using APDL command objects in Workbench’ is closed to new replies.
